Aug 15th, 2024, 1:24pm
Cgs and Cgs vs Vgs (Read 4454 times)
baab
EA
Cgs and Cgs vs Vgs
Mar 14th, 2014, 7:06pm
Hi.
I set up this circuit for simulation Cgs and Cgs as Vgs changes.
Below are the curves Cgs and Cgs vs Vgs.
(please see it in the second post. The forum doesn't allow to post two images in a single post)
I have some questions, hope you can help.
1. Why Cgs and Cgs are negative?
2. Why Cgs and Csg are not equal?
Thanks.
baab
EA
Re: Cgs and Cgs vs Vgs
Reply #1 - Mar 14th, 2014, 7:07pm
And this is the curves Cgs and Cgs vs Vgs:
aaron_do
Reply #2 - Mar 16th, 2014, 10:18pm
Hi baab,
I think this has been discussed more than once before, but you will need to do a search. I believe it is just something to do with the way capacitance is defined in the model which makes it a negative value. Also, Cgs and Csg may not be defined exactly symmetrically. For your purposes (matching I assume), I guess you're probably better off doing an AC or SP analysis to find the capacitance since all the capacitance will be lumped together...
regards,
Aaron
baab
EA
Reply #3 - Mar 16th, 2014, 10:38pm
Thanks, Aaron.
You are correct. Here is the link to the previous discussion.
http://www.designers-guide.org/Forum/YaBB.pl?num=1087411058
As I understand from the link, the capacitance between G and S will be -Csg in BSIM3V3 model.
I am going to post a new thread about LNA design procedure that is very confusing. Hope you could help.
Reply #4 - Mar 18th, 2014, 4:21pm
See also my response to your identical question http://www.cadence.com/Community/forums/p/28791/1332097.aspx#1332097 - I'm assuming that's you, because it's an enormous coincidence otherwise.
Andrew
baab
EA
Reply #5 - Mar 20th, 2014, 12:20am
Thanks. yes, it is me.
