https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> hidden state in dff verilogA https://designers-guide.org/forum/YaBB.pl?num=1033687038 Message started by Betai on Oct 3rd, 2002, 4:17pm |
Title: hidden state in dff verilogA Post by Betai on Oct 3rd, 2002, 4:17pm How can I get rid of hidden state problem in the following dff code ? module d_ff(vin_d, vclk, vout_q, vout_qbar); input vclk, vin_d; output vout_q, vout_qbar; electrical vout_q, vout_qbar, vclk, vin_d; parameter real vlogic_high = 5; parameter real vlogic_low = 0; parameter real vtrans_clk = 2.5; parameter real vtrans = 2.5; parameter real tdel = 3u from [0:inf); parameter real trise = 1u from (0:inf); parameter real tfall = 1u from (0:inf); integer x; analog begin @ (cross( V(vclk) - vtrans_clk, +1 )) x = (V(vin_d) > vtrans); V(vout_q) <+ transition( vlogic_high*x + vlogic_low*!x, tdel, trise, tfall ); V(vout_qbar) <+ transition( vlogic_high*!x + vlogic_low*x, tdel, trise, tfall ); end endmodule |
Title: Re: hidden state in dff verilogA Post by Ken Kundert on Oct 5th, 2002, 2:05pm Here is a simple replacement for your D flip-flop model. My parameters are not the same as yours, so you might need to do a little touch up to make this one a drop-in replacement for yours. When using it be careful to keep the transition delay (td) and transition time (tt) short to reduce the chance that a transition could occur at a shooting interval boundary, which would cause convergence problems (see the hidden state paper on the website). Code:
Unfortunately when I run this model with the currently available version of Spectre it fails due to a bug in the idt code. The bug has been fixed and the fix will be released in the next roll up, but I'm afraid this model does not solve your problem today. Is there anyone that has a model that works with existing versions of Spectre? |
Title: Re: hidden state in dff verilogA Post by ronv on Oct 10th, 2002, 2:31pm The only clean way to incorporate an internal state into a Verilog-A model that will be used in SpectreRF is to hold the value as a capacitor voltage. The implementation can be equivalent to a real sample-and-hold type structure: Place a capacitor from the node that's used to hold the value to ground, and connect it to the signal that it needs to follow through an effective switch (small or big resistor, depending whether you're sampling or not). When it's not being driven, it can be slowly discharged through a big RC time constant. If there's only a limited number of states possible (such as logic levels, or a moderate number of integer states), it can be maintained through regenerative feedback: drive the output toward the nearest state rather than letting it float when it isn't being externally driven. /////Example: simple D latch (output follows input when clock is high): module d_latch_rf (clk, d, q); input clk,d; output q; electrical clk,d,q; parameter real v0=0, v1=5; // low & high output levels parameter real vth=(v1+v0)/2 from (v0:v1); // threshold level (input & output) parameter real TauOut=0.2u; // time constant for following input integer Lout; // desired output logic level real VoutNom; // nominal output voltage analog begin if (V(clk)>vth) Lout = (V(d)>vth); // clk high: state defined by D input else Lout = (V(q)>vth); // clk low: state follows output VoutNom = Lout? v1:v0; // get nominal output voltage I(q) <+ ddt((TauOut/1.0)*V(q)); // hold capacitor I(q) <+ (V(q)-VoutNom)/1.0; // 1ohm resistor drives Vout from VoutNom end endmodule If you needed to fully control the output waveshape with a transition statement in the above example, you could just let the "q" node be an internal node, and drive the actual output node using a transition statement based on the "VoutNom" value: V(qout) <+ transition(VoutNom,Td,Tr,Tf); But, to make an edge-triggered sample-and-hold, you can't really change the capacitor voltage on a single timestep to do a real edge trigger. Instead, the circuit-equivalent implementation would be to use a dual track-and-hold arrangement: - First stage tracks when the clock is low, holds when it's high; - Second stage tracks when the clock is high, holds when it's low. Thus, on the leading clock edge, the input value which was being tracked is transferred to output, resulting in proper leading-edge-triggered result. /////Example: DFF implemented via dual track-and-hold format. module d_ff_rf (vin_d, vclk, vout_q, vout_qbar); input vclk, vin_d; output vout_q, vout_qbar; electrical vout_q, vout_qbar, vclk, vin_d; electrical X1,X2; // node for first and second stage states parameter real vlogic_high=5,vlogic_low=0; parameter real vtrans=(vlogic_high+vlogic_low)/2; parameter real tdel=3u, trise=1u, tfall=1u; parameter real tau=trise/10; integer Lclk,Lvin,Lx1,Lx2; // current state for each node integer Kx1,Kx2; // desired state for track-and-holds analog begin // Convert all signals to logic 1/0 format: Lclk = (V(vclk)>vtrans); Lvin = (V(vin_d)>vtrans); Lx1 = (V(X1)>0.5); Lx2 = (V(X2)>0.5); // force last point before transition to accurately measure input at crossing: @(cross( V(vclk)-vtrans,+1 )) Lclk=0; // compute new logic states desired: Kx1 = Lclk? Lx1:Lvin; Kx2 = Lclk? Lx1:Lx2; // capacitors for each state, and drive each through 1 ohm resistance: I(X1) <+ ddt(tau*V(X1)); I(X2) <+ ddt(tau*V(X2)); I(X1) <+ (V(X1)-Kx1)/1.0; I(X2) <+ (V(X2)-Kx2)/1.0; // output using transition statement as ideal voltage, and inversion: V(vout_q) <+ transition(Kx2? vlogic_high:vlogic_low ,tdel,trise,tfall); V(vout_qbar) <+ vlogic_high+vlogic_low - V(vout_q); end endmodule .........................................................Ron |
