https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Can I set output waveform as "tr0" forma https://designers-guide.org/forum/YaBB.pl?num=1076895091 Message started by Terence on Feb 15th, 2004, 5:31pm |
Title: Can I set output waveform as "tr0" forma Post by Terence on Feb 15th, 2004, 5:31pm Hi, Spectre is my only simulator and I need to analyze the output by another tool which accepts only "tr0" data. "tr0" is Hspice format. Can I set output waveform as "tr0" format while using transient analysis in Spectre simulation ? ??? |
Title: Re: Can I set output waveform as "tr0" f Post by Andrew Beckett on Mar 4th, 2004, 10:27am No. |
