https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Simulating SC filters with SpectreRF example https://designers-guide.org/forum/YaBB.pl?num=1080512533 Message started by delta sigma tim on Mar 28th, 2004, 2:22pm |
Title: Simulating SC filters with SpectreRF example Post by delta sigma tim on Mar 28th, 2004, 2:22pm Hi, I wonder if anyone who run the “Simulating SC filters with SpectreRF” example successfully can help me. First I’m running spectre ver. 4.4.5.100.9 -- 20 Apr 2000. And I used the following command that is recommended by Cadence “Using AWD with standalone Spectre”: spectre +log spectre.out -f psfbin -r ./psf -E tah.ckt I get the following warning: “Warning from spectre during circuit read-in. smpldNoise: `numberofpoints' is not a valid parameter for an instance of `pnoise'. Ignored.” I also couldn’t figure out how to get `numberofpoints' option using the GUI either. Actually that is why I tried the standalone option. Another problem I encountered with the example is with sh.va, I got the following error message: “Error found by spectre during AHDL read-in. "sh.va", line 29: "n = ($abstime <<--? - tdelay + aperture) / period + 0.5;" "sh.va", line 29: Error: syntax error "sh.va", line 34: "n = ($abstime <<--? - tdelay) / period + 0.0;" "sh.va", line 34: Error: syntax error "sh.va", line 39: "if (($abstime <<--? > tstop - aperture) && ($abstime <= tstop)) " "sh.va", line 39: Error: syntax error "sh.va", line 51: "if (($abstime <<--? >= tstop - aperture) && ($abstime < tstop)) begin" "sh.va", line 51: Error: syntax error file: sh.va. Non-recoverable error: parser error: confused context stack. Exiting SpectreHDL compilation.” thanks Hi, I |
Title: Re: Simulating SC filters with SpectreRF example Post by August West on Mar 28th, 2004, 8:49pm Tim, Your version is too old. Time to upgrade. You can avoid the $abstime problem by using $realtime, but the other problem suggests that the version you are using does not support the strobed noise. -August |
Title: Re: Simulating SC filters with SpectreRF example Post by Andrew Beckett on Mar 29th, 2004, 5:55am Actually it would support strobed noise, but you'd have to use noiseskipcount instead of numberofpoints - numberofpoints allows you to spread the strobe points over the PSS points by saying this is the total number of strobes you want; noiseskipcount says to do a strobe every nth timepoint. tdnoise has been there (released) since IC445 - it was there in engineering mode before that. However, I'd recommend using a later version anyway... - you'll need that to get the newer verilog-a syntax, as August said. Andrew. |
Title: Re: Simulating SC filters with SpectreRF example Post by delta sigma tim on Mar 29th, 2004, 3:20pm Thank you both very much. You are right, I had to update my source path to the newer version and everything works fine. Thanks |
