https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Suggest me the architecture of Ring VCO! https://designers-guide.org/forum/YaBB.pl?num=1083139518 Message started by VincentLee on Apr 28th, 2004, 1:05am |
Title: Suggest me the architecture of Ring VCO! Post by VincentLee on Apr 28th, 2004, 1:05am Hello everyone, I am designing a VCO in a PLL which uses for clock generator in MCU. So its operating frequency is not very high, tuning range is about 10MHz~200MHz. And it will be implemented by CMOS 0.6um process with 5V power supply. In addition, the input control voltage also needs wide control range. In many specs, I focus on the lower phase noise characteristics and higher PSRR. Firstly, due to the low frequency application, I select the Ring VCO. However, there are so lots of IEEE papers about the Ring VCO that I can't decide which one is best for me. So please suggest me the achitecture of Ring VCO! I would like use the differential cascode structure to build my Ring VCO, how do you think about its performence? Thanks in advance! Best Regards, Vincent |
Title: Re: Suggest me the architecture of Ring VCO! Post by Augustine B Lytan on Apr 29th, 2004, 11:21am Hi, The delay with balanced loads by maneatis is one of the most popular one as it has very good psrr. you can have a look at the paper: Low-jitter Process-Independent DLL and PLL Based on Self-Bias Techniques Author: John G. Maneatis IEEE Journal of Solid-state circuits, Vol 31, No 11, November 1996. Hope this helps. Regards, augustine. |
