https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> plotting fMAX https://designers-guide.org/forum/YaBB.pl?num=1083463568 Message started by tony on May 1st, 2004, 7:06pm |
Title: plotting fMAX Post by tony on May 1st, 2004, 7:06pm does anyone have any tips on plotting the fmax of a device versus collector or drain current depending on the device type, bjt or fet ? for MAG don't the input and outputs have to be conjugate matched ...so do you have to alter the match for every change in the device sizes ? thank you |
