https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> RF Probing on Aluminum pads https://designers-guide.org/forum/YaBB.pl?num=1083872736 Message started by Fei on May 6th, 2004, 12:45pm |
Title: RF Probing on Aluminum pads Post by Fei on May 6th, 2004, 12:45pm I did some measurements on chip, which has aluminum pads for probing. Probe contact was a headache for me. Anyone has suggestions on what type of probe should be using in this case. Thanks |
Title: Re: RF Probing on Aluminum pads Post by caduser on Aug 17th, 2004, 8:03pm Use cascade microtech G-S-G probes. I think the standard pitch is 100um. |
Title: Re: RF Probing on Aluminum pads Post by MTYang on Sep 20th, 2005, 6:44pm I assumed you have used the AuBe probe for Au pad probing. Please try the W probe which developed for Al pad, respectively. You can get it from Cascade or GGB. |
