Design >> Mixed-Signal Design >> VCO Duty Cycle
https://designers-guide.org/forum/YaBB.pl?num=1085576215
Message started by bhupendra on May 26th, 2004, 4:56am
Title: VCO Duty Cycle
Post by bhupendra on May 26th, 2004, 4:56am
we're working on 400 MHz VCO Design. We've used current starved type VCO. This works fine and gives proper duty cycle with all corner cases except FF 0 3.7V
and FF 85 3.7V. Its duty cycle is varying. So how can we proceed with this issue.
Title: Re: VCO Duty Cycle
Post by neoflash on Nov 11th, 2005, 6:57am
Can you put the schematic?
Post by juddy on Dec 3rd, 2005, 7:47am
Have you check DC operation points at your refered cornner?
