https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> Interpolation Computing Code.What's wrong in it? https://designers-guide.org/forum/YaBB.pl?num=1086329644 Message started by cyjim on Jun 3rd, 2004, 10:14pm |
Title: Interpolation Computing Code.What's wrong in it? Post by cyjim on Jun 3rd, 2004, 10:14pm I wrote the code below,but I can't compile it successfully.Can you help me,what's wrong in it? Thanks a lot! cyjim ------------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity lineinter is port(reset:in std_logic; clk:in std_logic; xe,ye:in signed(15 downto 0); cpx1,cpx2,cpy1,cpy2:0ut std_logic); end entity lineinter; architecture lineinter_arch of lineinter is begin process(clk,reset,xe,ye) variable c,d,e,f:std_logic; variable q:signed(31 downto 0); variable r,s:signed(15 downto 0); begin if reset='0' then q:=(others=>'0');r:=(others=>'0');s:=(others=>'0'); elsif clk'event and clk='1' then a:loop q:=xe*s-r*ye; if (xe(15)='0') and (ye(15)='0') then if q(31)='0' then c:='1';q:=q-ye;r:=r+1; else e:='1';q:=q+xe;s:=s+1; end if; end if; if (xe(15)='1') and (ye(15)='0') then if q(31)='0' then e:='1';q:=q+xe;s:=s+1; else d:='1';q:=q+ye;r:=r-1; end if; end if; if (xe(15)='1') and (ye(15)='1') then if q(31)='0' then d:='1';q:=q+ye;r:=r-1; else f:='1';q:=q-xe;s:=s-1; end if; end if; if (xe(15)='0') and (ye(15)='1') then if q(31)='0' then f:='1';q:=q-xe;s:=s-1; else c:='1';q:=q-ye;r:=r+1; end if; end if; cpx1<=c;cpx2<=d;cpy1<=e;cpy2<=f; exit a when r=xe and s=ye; end loop a; end if; end process; end architecture lineinter_arch; |
Title: Re: Interpolation Computing Code.What's wrong in i Post by Andrew Beckett on Jun 4th, 2004, 12:02am I tried compiling this with: Code:
and it gave some fairly clear errors: Code:
If you look at the line in your code it is complaining about: Code:
you'll see you've written 0ut instead of out. If I fix that, it compiles OK. You didn't say which tool you were using here, but the lesson is probably to pay attention to the error messages! Regards, Andrew. |
Title: Re: Interpolation Computing Code.What's wrong in i Post by cyjim on Aug 22nd, 2004, 4:40pm Hi,Andrew! Thanks a lot for your reply to my topic. I have put the problems straight. best regards, cyjim |
