https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> signed logical operations in VHDL https://designers-guide.org/forum/YaBB.pl?num=1094839572 Message started by neocool on Sep 10th, 2004, 11:06am |
Title: signed logical operations in VHDL Post by neocool on Sep 10th, 2004, 11:06am Hi, I am fairly new to VHDL. I am designing BPSK modulator and want it to output unsigned or 2's compliment format depending on the register settings I choose (so software selectable). I am wondering, how would you work with unsigned and 2's compliment in VHDL. Do you have to do all math manually or there are any special functions that can sum/subtract two 2's compliment numbers automatically? I have to use multiplication and addition of signals in my code. Thanks for any help in advance |
Title: Re: signed logical operations in VHDL Post by Paul on Sep 13th, 2004, 12:57pm Hello, you can define your signals as unsigned, a predefined signal type. All operations on this type are predefined too. As far as I remember, synthesis tools also understand 'unsigned' correctly and the signals will be synthesized as a n-bit logic signal. Paul |
Title: Re: signed logical operations in VHDL Post by neocool on Sep 21st, 2004, 11:04am thanks I've partially answered this question myself. Apparently, signed ports did not work for me. I had to cast slv to signed, then do multiplication and then cast it back to slv. THe result contained 2's compliment number thanks |
