https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Spice3f5 on Linux/cygwin Bugs https://designers-guide.org/forum/YaBB.pl?num=1095186554 Message started by Rahul on Sep 14th, 2004, 11:29am |
Title: Spice3f5 on Linux/cygwin Bugs Post by Rahul on Sep 14th, 2004, 11:29am Hi All. I am trying to compile spice3f5sfix on linux/cygwin. After fixing many things in the make files I get one very wierd error in the string.c and misc.h files In function `bcopy': 09: error: argument `from' doesn't match prototype Has anyone fixed this problem ? Thanks Rahul |
Title: Re: Spice3f5 on Linux/cygwin Bugs Post by Rahul on Sep 16th, 2004, 11:10pm Pardon me for taking the Forum's time and bandwidth, The bug is a cygwin problem and not linux. I was able to compile it on linux. Thanks -Rahul |
Title: Re: Spice3f5 on Linux/cygwin Bugs Post by tcad on Aug 27th, 2005, 10:01pm Do you still have problem to compile spice on cygwin? This is neither a linux problem nor cygwin. You need to make some change accordingly in conf and os_port.h. I can compile on both linux and cygwin system. Thanks, Min |
Title: Re: Spice3f5 on Linux/cygwin Bugs Post by antonios on Oct 4th, 2005, 8:48am hello, i am trying to install spice3f5 in linux i still have some problems but i ws told that if i install the termcap libraries it will work. my question is: what things i willl have to change in order to install spice3f5 in cygwin? thank you in advance be well antonios |
