https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> saving data of the simulation result in cadence https://designers-guide.org/forum/YaBB.pl?num=1100060451 Message started by uncle_ezra on Nov 9th, 2004, 8:20pm |
Title: saving data of the simulation result in cadence Post by uncle_ezra on Nov 9th, 2004, 8:20pm How do I save data of the simulation result in cadence so I can export to matlab or excel? And where is wavescan in ADE? Thanks |
Title: Re: saving data of the simulation result in cadenc Post by xiaolong on Dec 9th, 2004, 5:39pm Here is a simple method: 1> Use wavwscan open the simulation result; 2> In Graph Display window select the curve you want to save; 3> In menu choose "Trace -> Save...". |
