https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Current bias circuit design https://designers-guide.org/forum/YaBB.pl?num=1105857023 Message started by gogomi on Jan 15th, 2005, 10:30pm |
Title: Current bias circuit design Post by gogomi on Jan 15th, 2005, 10:30pm Hi, I would like to desing a current bias circuit for LC-VCO and charge pump. Could anyone give me some suggestions on reference or circuit topology. Actually, I've tried to build a supply-independent bias circuit but it's hard to get the current I need and it fails to be supply-independent. Thank you for your help gogomickey |
Title: Re: Current bias circuit design Post by Frank Wiedmann on Jan 16th, 2005, 11:48pm See http://www.stanford.edu/class/ee214/handouts/h33_lecture25.pdf, http://www.stanford.edu/class/ee214/handouts/h34_lecture26.pdf and http://www.stanford.edu/class/ee214/handouts/h35_lecture27.pdf or any decent textbook on analog integrated circuit design (see http://www.designers-guide.com/Books/ for some suggestions). |
Title: Re: Current bias circuit design Post by gogomi on Jan 17th, 2005, 7:36pm Thank you! I'll take a look at them. |
Title: Re: Current bias circuit design Post by neoflash on Nov 11th, 2005, 7:02am Frank Wiedmann wrote on Jan 16th, 2005, 11:48pm:
they are no longer available, can you upload then here? |
Title: Re: Current bias circuit design Post by kadison on Dec 18th, 2005, 9:01am Hi, Since the handouts are no longer available. Could anyone provide me a copy for reference? Or where can I get the material even I have to pay for that? Thanks, kadison |
