https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Spectre simulator and Analysis temparature https://designers-guide.org/forum/YaBB.pl?num=1107121093 Message started by mreja on Jan 30th, 2005, 1:38pm |
Title: Spectre simulator and Analysis temparature Post by mreja on Jan 30th, 2005, 1:38pm Jan 30, 2005 Mr. Andrew, Thank you very much for replaying my question in the subject line. For your better understanding, I like to mention that: For example I am running simulation for a particular circuit at 27 oC (the analysis temparature in the analog environment window). How, I will know that the actual circuit will work from 0 to 100 oC (ambient temparature). In this case, how I have to set the analysis temparature. Would please tell me, How I will set up analysis temparature for the real world environment temparature ( 0 to 100 0C). What change I have to make in "temp" or "tnom" or other parameters. Best regards Mahbub Reja |
Title: Re: Spectre simulator and Analysis temparature Post by Andrew Beckett on Jan 31st, 2005, 9:44pm Mahbub, Not sure why you sent me two messages as well as this, within a few minutes of each other. Anyway, as I said, you would not touch tnom. You'd set temp to a reasonable range - bearing in mind that temp is the device temperature rather than ambient temperature (it will probably be hotter at the device than in the surrounding air). Exactly the temperature range you choose will depend on the application and how much power the circuit is using, probably. I'm not entirely certain I understand what you're asking. Andrew. |
