https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> Fractional-N synth phase noise measurements https://designers-guide.org/forum/YaBB.pl?num=1107179605 Message started by benbassa on Jan 31st, 2005, 5:53am |
Title: Fractional-N synth phase noise measurements Post by benbassa on Jan 31st, 2005, 5:53am Hi, Does any one have an idea how to simulate the phase noise of a fractional-N synthesizer in spectre ? I read somewhere that since its not periodic the simulator fails to converge. Thanks, Assaf, |
Title: Re: Fractional-N synth phase noise measurements Post by Jitter Man on Jan 31st, 2005, 10:52am It is not easy, but it is also not impossible. You can read about it in "Modeling jitter in PLL-based frequency synthesizers" in http://www.designers-guide.com/Analysis/. [glb]Jitter Man[/glb] |
Title: Re: Fractional-N synth phase noise measurements Post by benbassa on Jan 31st, 2005, 11:26pm Thanks, But I was looking for a direct way so the real devices will be simulated. Not to use a model for simulation. Assaf, |
