https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Phase noise inc 1/f noise affects using tdnoise in https://designers-guide.org/forum/YaBB.pl?num=1108506188 Message started by ic_engr on Feb 15th, 2005, 2:23pm |
Title: Phase noise inc 1/f noise affects using tdnoise in Post by ic_engr on Feb 15th, 2005, 2:23pm Hello, I successfully Ran tdnoise for my oscillator. I also ran standard pnoise. The fc corner is around 200Hz. From the tdnoise I integrated the noise from 1kHz to 2MHz since my fo=4MHz. This oscillator is for audio application. Therefore, I would like to know if the integrated noise using the band would be okay. Secondly, Can I now divide the number I get from above by 2*pi*fo or should I divide this by trise of the ring oscillator output node from one of the stages. Does this calculation include fliker noise affects if I have include flicker noise in the models. For long term jitter can I now multiply this number by sqrt(fo*TIE). Thanks ic_engr |
