https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> FFT analysis using HSpice https://designers-guide.org/forum/YaBB.pl?num=1108717920 Message started by snoop835 on Feb 18th, 2005, 1:12am |
Title: FFT analysis using HSpice Post by snoop835 on Feb 18th, 2005, 1:12am Hi everyone, I am a beginner in analog design. I want to simulate first order delta sigma modulator for dynamic range analysis i.e. SFDR. What I did was , I run the FFT analysis in parallel with the transient analysis. Then at the simulation output plot, for SFDR measurement, I simply measure the difference between peak amplitude of fundamental frequency to the peak of first harmonics. Is this the correct way of doing it? Many thanks What about INL/DNL analysis? Can I measure INL DNL using HSpice (Monte Carlo analysis)? Anyone knows good website/ tutorial /application notes on this? |
