https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> How to simulate DAC performance? https://designers-guide.org/forum/YaBB.pl?num=1110772631 Message started by Leyman on Mar 13th, 2005, 7:57pm |
Title: How to simulate DAC performance? Post by Leyman on Mar 13th, 2005, 7:57pm Hi everyone! How to simulate for DAC performance i.e. INL, DNL, Gain Error, Offset Error etc. What kind of EDA toold do I need for this? Can I simulate using HSpice? Really appreciate if someone can help!..CHEERS :) |
Title: Re: How to simulate DAC performance? Post by sheldon on Mar 30th, 2005, 10:51pm Leyman, There are examples of how to implement the INL and DNL tests for D/A Converters in the Cadence ICXX ahdlLib. The models default to 8 bits, but internally the number of bits is parameterized and easily modified. Calculating the gain and offset error should be fairly straightforward. Simulate the transfer function (zero scale and full scale output) then use the Calculator to simulate the slope[gain] and crossing point[offset]. In the past, I have used Spectre for simulating D/A Converters both at the behavioral and transistor level. One final comment, simulating D/A Converter dynamic performance is more of a challenge. If you use testbenches that are appropriate for A/D Converters, then the DAC output will look like a "picket fence", that is, the noise in the spectrum is concentrated at the tones of the beat frequency so measuring Spurious Free Dynamic Range is difficult. Best Regards, Art Schaldenbrand |
