https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Unsder which type analysis HB_meth is implemented https://designers-guide.org/forum/YaBB.pl?num=1111077666 Message started by fchirouf on Mar 17th, 2005, 8:41am |
Title: Unsder which type analysis HB_meth is implemented Post by fchirouf on Mar 17th, 2005, 8:41am Hi all; I would know which analysis type in spectreRF, I can used HB-algorithm to analysis Steady-State of my oscillator circuit? It's qpss, pAC,... for example. Advance thinks Chirouf- |
Title: Re: Unsder which type analysis HB_meth is implemen Post by Andrew Beckett on Mar 20th, 2005, 2:41am SpectreRF does not have a harmonic balance analysis. Instead of harmonic balance you have Periodic Steady State, or Quasi-Periodic Steady State - which are different approaches for the same kind of problem. See http://www.designers-guide.org/Analysis/rf-sim.pdf for a comparison of different simulation algorithms. Andrew. |
