https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> how to plot op parameter curve in hspice? https://designers-guide.org/forum/YaBB.pl?num=1113877217 Message started by microant on Apr 18th, 2005, 7:20pm |
Title: how to plot op parameter curve in hspice? Post by microant on Apr 18th, 2005, 7:20pm Hi everyone, I meet a problem with Avanti Hspice. I want to plot the curve of MOSFET operation point parameter such as gm,cgs,cgtot etc when i run a DC parameter sweep. but it seem that hspice didn't have this function, could anyone give me some advise? thanks and best regrads microant ??? |
Title: Re: how to plot op parameter curve in hspice? Post by 020170 on Apr 21st, 2005, 4:56pm sorry. i don't know cgs, cgtot. but if you want to know gm in saturation region, I can help you in saturation, gm = root( 2 * K' * W/L * Idsat ) I wish that it was helpful |
Title: Re: how to plot op parameter curve in hspice? Post by Andrew Beckett on Apr 21st, 2005, 9:45pm I remember from many years ago that this was done with the element access functions LVnn() and LXnn() wher nn was a number which determines which parameter to output. This is covered in the HSPICE manual, I'm sure (it was 10 years ago when I used HSPICE, so I'm sure it is now). Regards, Andrew. |
Title: Re: how to plot op parameter curve in hspice? Post by James on Apr 22nd, 2005, 7:15am Plotting Variables Use this template to plot internal variables, such as: i(mn1) i1, i2, i3, or i4 can specify the true branch currents, for each transistor node. LV18(mn6) Total gate capacitance (C-V plot). LX7(mn1) GM gate transconductance. (LX8 specifies GDS, and LX9 specifies GMB). |
Title: Re: how to plot op parameter curve in hspice? Post by James on Apr 22nd, 2005, 7:22am Here is an example from Hspice user-guide MOS I-V and C-V Plot Example Input File *FILE: MOSIVCV.SP IDS, VGS, CV AND GM PLOTS .OPTION SCALE=1U DCCAP .DC VDDN 0 5.0 .1 $VBBN 0 -3 -3 sweep supplies .PARAM ww=8 LL=2 $ ids-vds curves .GRAPH 'I_VG=1' =I(MN1) 'I_VG=2' =I(MN2) 'I_VG=3' =I(MN3) + 'I_VG=4' =I(MN4) .GRAPH 'I_VG=-1'=I(MP1) 'I_VG=-2'=I(MP2) 'I_VG=-3'=I(MP3) + 'I_VG=-4'=I(MP4) $ ids-VGs curves .GRAPH 'I_VD=.5'=I(MN6) 'I_VD=-.5'=I(MP6) $ gate caps (cgs+cgd+cgb) .GRAPH 'CG-TOT_N'=LX18(MN6) 'CG-TOT_P'= LX18(MP6) $ gm .GRAPH 'GM_N'=LX7(MN6) 'GM_P'=LX7(MP6) VDDN vdd_n gnd 5.0 VBBN vbb_n gnd 0.0 EPD vdd_p gnd vdd_n gnd -1 $ reflect vdd for P devices EPB vbb_p gnd vbb_n gnd -1 $ reflect vbb for P devices V1 vg1 gnd 1 V2 vg2 gnd 2 V3 vg3 gnd 3 V4 vg4 gnd 4 V5 vddlow_n gnd .5 V-1 vg-1 gnd -1 V-2 vg-2 gnd -2 V-3 vg-3 gnd -3 V-4 vg-4 gnd -4 V-5 vddlow_p gnd -.5 MN1 vdd_n vg1 gnd vbb_n N W=ww L=LL MN2 vdd_n vg2 gnd vbb_n N W=ww L=LL MN3 vdd_n vg3 gnd vbb_n N W=ww L=LL MN4 vdd_n vg4 gnd vbb_n N W=ww L=LL MP1 gnd vg-1 vdd_p vbb_p P W=ww L=LL MP2 gnd vg-2 vdd_p vbb_p P W=ww L=LL MP3 gnd vg-3 vdd_p vbb_p P W=ww L=LL MP4 gnd vg-4 vdd_p vbb_p P W=ww L=LL MN6 vddlow_n vdd_n gnd vbb_n N W=ww L=LL MP6 gnd vdd_p vddlow_p vbb_p P W=ww L=LL .MODEL N NMOS LEVEL=3 VTO=0.7 UO=500 KAPPA=.25 ETA=.01 + THETA=.04 VMAX=2E5 NSUB=9E16 TOX=400 KP=30U GAMMA=1.5 + PB=0.6 JS=.1M XJ=0.5U LD=0.1U NFS=1E11 NSS=2E10 + RSH=80 CJ=.3M MJ=0.5 CJSW=.1N MJSW=0.3 acm=2 capop=4 .MODEL P PMOS LEVEL=3 VTO=-0.8 UO=150 KAPPA=.25 KP=15U + ETA=.015 THETA=.04 VMAX=5E4 NSUB=1.8E16 TOX=400 GAMMA=.67 + PB=0.6 JS=.1M XJ=0.5U LD=0.15U NFS=1E11 NSS=2E10 + RSH=80 CJ=.3M MJ=0.5 CJSW=.1N MJSW=0.3 acm=2 capop=4 .END |
Title: Re: how to plot op parameter curve in hspice? Post by microant on Apr 24th, 2005, 7:51pm :D thanks for James and Andrew, i have plot it! i use the .meas statement and the ac analysis to plot it. **single MOS performance test .PARAM vinp=1 ibias=1u vcc=5 .PARAM vg1=1 vd1=2 .OP all .AC dec 2 100 1k sweep data=corner2 .DATA corner2 tem -40 25 60 125 .ENDDATA *** output ***AC small-param .MEAS AC GM find lx7(MN1) at=1k .MEAS AC GDS find lx8(MN1) at=1k .MEAS AC GMB find lx9(MN1) at=1k .MEAS AC VTH find lv9(MN1) at=1k .MEAS AC VDSAT find lv10(MN1) at=1k *** voltage .MEAS AC VGS find lx2(MN1) at=1k *** capacitance at each terminal .MEAS AC Cgtot find lx18(MN1) at=1k .MEAS AC Cgd find lx19(MN1) at=1k .MEAS AC Cgs find lx20(MN1) at=1k .MEAS AC Cbg find lx21(MN1) at=1k .MEAS AC Cbd find lx22(MN1) at=1k .MEAS AC Cbs find lx23(MN1) at=1k .MEAS AC Cdtot find lx33(MN1) at=1k .MEAS AC Cdg find lx32(MN1) at=1k .MEAS AC Cds find lx34(MN1) at=1k .MEAS AC Cstot param='-Cgs-Cbs-Cds' .MEAS AC Cbtot param='-Cbg-Cbs-Cbd' *** netlist *** MN1 VD1 VG1 0 0 nch l=4u w=2u m=1 MN2 VG2 VG2 0 0 nch l=4u w=2u m=1 I1 VCC VG2 dc ibias V1 VCC 0 dc vcc VG1 VG1 0 dc vg1 ac 1 VD1 VD1 0 dc vd1 best regard microant |
