https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Corner simulations in Spectre https://designers-guide.org/forum/YaBB.pl?num=1114761261 Message started by Alez on Apr 29th, 2005, 12:54am |
Title: Corner simulations in Spectre Post by Alez on Apr 29th, 2005, 12:54am Dear all, I plan to test (in simulation) my circuit with varying all cases of the provided transistor model, e.g. FF/SS/SF/FS. Could you suggest me how to do this in Cadence Spectre ? Thank you in advance, Alez |
Title: Re: Corner simulations in Spectre Post by Paul on Apr 30th, 2005, 12:52pm Alez, If you searched this forum for "corner simulation", you would have found the following post: http://www.designers-guide.org/Forum/?board=ms_design;action=display;num=1074857505 For the exact simulation set-up and the parameters to be set, you will find it in the Cadence Advanced Analysis Tools User Guide, Chapter 1, Corner Analysis. In ADE, select Tools->Corners. One suggestion: use a configuration file (PCF file) to set the corner information in the corner tool, instead of filling in the information by hand. It is easy to write (get inspiration from the User's Guide) and much more flexible if you want to add variable sweeps. Paul |
Title: Re: Corner simulations in Spectre Post by Alez on May 3rd, 2005, 11:26pm Thank you Paul. This helps on my simulation a lot :) |
