https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> Phase noise difference concerning Ken's Paper https://designers-guide.org/forum/YaBB.pl?num=1118767544 Message started by tromeros on Jun 14th, 2005, 9:45am |
Title: Phase noise difference concerning Ken's Paper Post by tromeros on Jun 14th, 2005, 9:45am Hi, I followed the example concerning jitter measurement that is on page 45 of Ken's paper "Predicting the phase noise and jitter of PLL-based frequency synthesizers" . When I simulate the VCO/10000 circuit on its own, I get an Sphi of -60db/Hz @ 1KHz offset. There is approximately a 50db difference between what I get and what I see in figure 18 of the paper. I 've repeteadly checked the code and I wonder if trere is something I haven't considered. Thanx a lot. |
Title: Re: Phase noise difference concerning Ken's Paper Post by Tommy on Jun 14th, 2005, 9:18pm The result obtained from the script has to be compensated for non-unity-RBW & suppression of dividers (80-28=52db) : page 44. Tommy |
Title: Re: Phase noise difference concerning Ken's Paper Post by tromeros on Jun 17th, 2005, 5:27am Hi, I have some additional questions concerning the MATLAB code. The PSD figure (page 46) in Ken's paper has a frequency range from 300Hz to 100KHz. I simulate a PLL that has a VCO output frequency of 1G and a frequency divide ratio of 4. Because the ratio is small I simulate it for 10us and I set the outstart variable that exist in VCO's code at a value of 1us. In matlab, the frequency range of Sphi that I get, varies from 500Khz to 100MHz which is quite different fron the paper. My questions are: -Does the frequency at the output of the divider(250MHz in my case) affect the frequency range of the psd? -Does the simulation time have an impact in frequncy range? -And finally how can I take the values of Sphi for a lower frequency? Thank a lot for the help. |
