https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> battery model https://designers-guide.org/forum/YaBB.pl?num=1119848140 Message started by boby on Jun 26th, 2005, 9:55pm |
Title: battery model Post by boby on Jun 26th, 2005, 9:55pm Hi, Does somebody know how to model an exhausted battery in the battery charger circuit? A huge Cap is ok? |
Title: Re: battery model Post by Eugene on Jun 27th, 2005, 10:47am The last time I modeled a battery for charge/discharge time scales I used a macro model composed of large capacitors, resistors, and I a couple of diodes. Since then, VerilogA has emerged. VerilogA should make it easy to model a battery. I would probably first try a large nonlinear capacitor and perhaps some nonlinear resistors. I'd have to see the charge and voltage profiles to say much more. I am almost certain the profiles will depend on the type of battery you are modeling. |
Title: Re: battery model Post by sheldon on Jun 28th, 2005, 2:08am Boby, Try the model in the following reference, " A PSPICE Macro-Model for Li-Ion Batteries", Sean Gold, Battery Conference on Applications and Advances, 1997. It is relatively easy to implement this model in Verilog-A using table models. It is a little more work than using a capacitor but it is a better model of the load your charger will be driving. You might also want to try the following source, http://www.analoghome.com/articles.html. In the past, Steve has provided information on some of the battery models he has published in the past. Best Regards, Sheldon |
