https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Why no CAP and RES check report in LVS resul https://designers-guide.org/forum/YaBB.pl?num=1120122845 Message started by jayjay on Jun 30th, 2005, 2:14am |
Title: Why no CAP and RES check report in LVS resul Post by jayjay on Jun 30th, 2005, 2:14am Dear all, I am using the PDRACULA to do LVS, in the netlist there is description of CAP and RES such as: Cp n1 n2 1p xR2 n3 n4 rnwell l=100u w=3u But there is no CAP and RES check report in the final LVS result. Would you please tell me why. Thanks in advance Jay |
Title: Re: Why no CAP and RES check report in LVS resul Post by jayjay on Jun 30th, 2005, 10:09pm I guess that the LOGLVS complier can not regonize the RES and CAP in the input netlist, is it right? |
Title: Re: Why no CAP and RES check report in LVS resul Post by Andrew Beckett on Jul 4th, 2005, 2:25am In your CDL netlist, you need to have (at the top, although not on the first line): Code:
The *.BIPOLAR is needed in order for LOGLVS to realise that it is not a MOS-only design (the use of the word bipolar is a little archaic) - essentially, the idea was that resistors and capacitors would be representing parasitics, perhaps, and so should be filtered out in normal usage for LVS. Regards, Andrew. |
Title: Re: Why no CAP and RES check report in LVS resul Post by jay_lin on Jul 14th, 2005, 6:32am Dear Andrew, Thank you for your three-times' helps, I am so grateful. Have a nice day!! Jay |
