https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> variable tolerances in Spectre https://designers-guide.org/forum/YaBB.pl?num=1121762788 Message started by saumi on Jul 19th, 2005, 1:46am |
Title: variable tolerances in Spectre Post by saumi on Jul 19th, 2005, 1:46am Hi, I am using Cadence ICFB environment for my spectre transient simulations. Is it possible to specify different tolerances for different subcircuits in the schematic? That is, if I want to simulate a mixed signal circuit, can the tolerance for the digital control logic ckt be reduced to speed up the simulation? Regards, Saumitra |
Title: Re: variable tolerances in Spectre Post by Andrew Beckett on Jul 19th, 2005, 10:54am This can be done with UltraSim, but I don't think it's possible with spectre right now (unless something snuck in whilst I wasn't looking ;D Andrew. |
