https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> Pspice Modeling of BJT curve Ib vs Vbe https://designers-guide.org/forum/YaBB.pl?num=1123271781 Message started by vjoshi on Aug 5th, 2005, 12:56pm |
Title: Pspice Modeling of BJT curve Ib vs Vbe Post by vjoshi on Aug 5th, 2005, 12:56pm Now I have setup my circuit as follows. There is a current source at the base with step curent of 200mA and then a resistor of 1 G ohm is connected . So how do i measure for getting Ib vs Vbe curve . I am getting a linear curve having a slope of 1 when i run the probe for Ib vs V: Q1(b) (ie ) voltage across Base and emitter. Since the Base emitter junction is acting like a diode it should give me a flat curve for voltage less than threshold voltage and then at the voltage when the diode turns on it should give a vertical straight line high current at that threshold voltage. So can u advice where i am doing wrong or can u refer to someone who could help me out. |
Title: Re: Pspice Modeling of BJT curve Ib vs Vbe Post by Geoffrey_Coram on Aug 18th, 2005, 9:59am A step current of 200mA? Could be that's too large, and the junction current is linearized to avoid blowing up the exponential. |
