https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to measure PSRR in spectre https://designers-guide.org/forum/YaBB.pl?num=1125465191 Message started by SIRIUS on Aug 30th, 2005, 10:13pm |
Title: How to measure PSRR in spectre Post by SIRIUS on Aug 30th, 2005, 10:13pm Hi , Can anyone guide how to simulate for PSRR of voltage regulator using cadence spectre.Thanks in advance. |
Title: Re: How to measure PSRR in spectre Post by sheldon on Sep 1st, 2005, 7:16pm SIRIUS, Do you mean line and load regulation of the Voltage Regulator or PSRR of the op-amp used in the Voltage Regulator? Are you interested in small-signal effects, for example, 60dB of rejection, or are you interested in large signal effects, 3mV/V of supply variation? Best Regards, Sheldon |
Title: Re: How to measure PSRR in spectre Post by SIRIUS on Sep 2nd, 2005, 11:24pm I mean line and load regulation of the Voltage Regulator & interested in small-signal effects & large signal effects. |
