https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> PFD simulation problem with EldoRF https://designers-guide.org/forum/YaBB.pl?num=1125480400 Message started by trashbox on Aug 31st, 2005, 2:26am |
Title: PFD simulation problem with EldoRF Post by trashbox on Aug 31st, 2005, 2:26am Hi all, I used EldoRF to simulate the phase noise of PFD in PLL. However, the steady-state analysis can not be converged so that EldoRF can not continue the phase noise analysis. I have changed the related options(reltol & eps, sst_convergence_help etc.), there is no use. Then I put some small capacitors(~2fF) on the nodes of PFD's circuit by hand. For example, on the nodes of INV's output and DRAIN of nmos in NAND. The steady-state analysis of PFD can be converged. Why? If my circuit is very complicated(i.e.,I can not put small capacitors by hand in the netlist file) and I also can not find any commands which can add small capacitors on the node automatically. How to solve the steady-state analysis convergence problem during PFD simulation? Thank you very much. |
Title: Re: PFD simulation problem with EldoRF Post by dguser on Sep 13th, 2005, 1:39pm Hi, I am curious what is the number of harmonics that you used in the simuation. Also did you turn on the pre-conditioner (option SST_PRECONDITION) and increase the solver iteration limit (option SST_MAX_LINITER)? I would try TIME for pre-conditioner and increase the number of harmonics. If still fails, I would contact the Mentor folk. P.S: I am new to this forum. I tried to reply to this post earlier but am not sure if it went through. Anyway, sorry if you get duplicate responses. |
