https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> pnoise timedomain simulates extra time point https://designers-guide.org/forum/YaBB.pl?num=1125542338 Message started by huber on Aug 31st, 2005, 7:38pm |
Title: pnoise timedomain simulates extra time point Post by huber on Aug 31st, 2005, 7:38pm Hello- I'm trying to simulate the noise performance of a CMOS track-and-hold with spectreRF. I set noisetype=timedomain, numberofpoints=1, and noisetimepoints=[5.34e-9]. When I run the simulation it simulates an extra time point at t=0 (on the pss time axis), doubling the simulation time. Is there any way to make the simulator not do the t=0 time point? Thanks, -Dan |
Title: Re: pnoise timedomain simulates extra time point Post by Andrew Beckett on Aug 31st, 2005, 9:39pm Dan, Set numberofpoints to 0. numberofpoints is used to distribute timepoints over the period, in addition to any specified in noisetimepoints. If you don't want any distributed timepoints, set it to 0. Regards, Andrew. |
