https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> DSB or SSB NF for direct conversion receiver https://designers-guide.org/forum/YaBB.pl?num=1125621367 Message started by milkdragon on Sep 1st, 2005, 5:36pm |
Title: DSB or SSB NF for direct conversion receiver Post by milkdragon on Sep 1st, 2005, 5:36pm Hi all, Should i use DSB NF for the direct conversion receiver? I am doing simulation in SpectreRF and see different option to plot NF, one call NFieee, could any one tell what is it? Thank you |
Title: Re: DSB or SSB NF for direct conversion receiver Post by Eugene on Sep 1st, 2005, 7:03pm I am not yet familiar with the IEEE option but for direct conversion receivers I use the DSB option because the signal has power on both sides of the carrier. |
Title: Re: DSB or SSB NF for direct conversion receiver Post by Frank Wiedmann on Sep 1st, 2005, 11:21pm See http://www.cadence.com/whitepapers/pspapn1.pdf (this is also an appendix of the SpectreRF User Guide). |
Title: Re: DSB or SSB NF for direct conversion receiver Post by milkdragon on Sep 2nd, 2005, 9:45am Thank you |
