https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> SpectreRF&SPICE BJT mlodels!! https://designers-guide.org/forum/YaBB.pl?num=1128069279 Message started by fchirouf on Sep 30th, 2005, 1:34am |
Title: SpectreRF&SPICE BJT mlodels!! Post by fchirouf on Sep 30th, 2005, 1:34am Hi all I have a try to obtain the same transient simulation results when I simulate a simple BJT amplifier circuit with SpectreRF. I think that SpectreRF doesn’t accepte SPICE model. It has a way that I say to accept directly a SPICE model. I think BJT SpectreRF model is different to SPICE models!! Advance Thinks |
Title: Re: SpectreRF&SPICE BJT mlodels!! Post by Andrew Beckett on Sep 30th, 2005, 2:09am Nope. That's not it. Spectre can quite happily read SPICE models (and in the latest versions it can do this even more directly with the new front end in spectre). SpectreRF doesn't require different models to Spectre - it's the same simulator. So what really is your problem? Regards, Andrew. |
Title: Re: SpectreRF&SPICE BJT mlodels!! Post by fchirouf on Sep 30th, 2005, 2:36am so, i did including the SPICE device model as habituel area in netlist circuit : include "../../res.scs" section=restm include "../../cap.scs" section=captm include "../home/fchirouf/SPICE_BJT_models/2N2222.scs" So, spectreRF can read with out any problem the SPICE model BJT in fil 2N2222.scs |
