https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Problem of simulating Verilog AMS code on SimVison https://designers-guide.org/forum/YaBB.pl?num=1128535970 Message started by Murphy.Dave on Oct 5th, 2005, 11:12am |
Title: Problem of simulating Verilog AMS code on SimVison Post by Murphy.Dave on Oct 5th, 2005, 11:12am I did a behavoral model of sampling PLL in Verilog AMS and got no problem on compile and elaboration. But when I did a transient analysis with ncsim, I found the simulation results only show the value of last simulation time point. The data are shown unavailable for the simulation point during simulation time. Anyone knows what happened and how could it be fixed. Thanks in advance. Eric |
Title: Re: Problem of simulating Verilog AMS code on SimV Post by sheldon on Oct 6th, 2005, 4:45am Eric, Did you create probes to save the signal? Best Regards, Sheldon |
