https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> Question for Peaks on the PNoise Result's Curves https://designers-guide.org/forum/YaBB.pl?num=1129284499 Message started by tumeda on Oct 14th, 2005, 3:08am |
Title: Question for Peaks on the PNoise Result's Curves Post by tumeda on Oct 14th, 2005, 3:08am Hi I would like to know where these peaks on the curves of PNoise simulation come from ? As the description on the paper "jitter&Noise", after the -20dbc/Hz, the curve should be a flat line. Hier are the schematic of VCO and PNosie response. If you can not see the pictures, pls use right mouse to show the pictures. I am very appreciate your help. ![]() ![]() |
Title: Re: Question for Peaks on the PNoise Result's Curv Post by tumeda on Oct 15th, 2005, 1:20pm Pictures are updated! http://img140.photo.163.com/zoujunjx/17445359/441491786.jpg http://img140.photo.163.com/zoujunjx/17445359/441519850.jpg |
Title: Re: Question for Peaks on the PNoise Result's Curv Post by Ken Kundert on Oct 15th, 2005, 5:31pm Is the oscillation frequency approx 200MHz? If so, the bumps are the harmonics of the oscillation. -Ken |
Title: Re: Question for Peaks on the PNoise Result's Curv Post by tumeda on Oct 18th, 2005, 2:29am Thanks for Ken's guidance! I have found the frequency at the first bump is the VCO oscillation frequency. The other bumps are not very exact harmonic. Question: As long as I select the fc<delt_f<fvco , these bumps will not influence the jitter calculation, like as the delt_f=10M in this circuit. Is it right? |
Title: Re: Question for Peaks on the PNoise Result's Curv Post by Ken Kundert on Oct 18th, 2005, 9:32am Correct. The bumps are precisely at the harmonics, they just appear to be a different frequencies because of the frequency points used during the analysis. -Ken |
