https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> auLvs Creation https://designers-guide.org/forum/YaBB.pl?num=1130931641 Message started by maxtheshark on Nov 2nd, 2005, 3:40am |
Title: auLvs Creation Post by maxtheshark on Nov 2nd, 2005, 3:40am Hi, I'm trying to made a parametrized cell to design an integrated inductor using skill. The layout is correctely generated using the CDF parameters mask in Virtuoso Environmet, but when I include this component in an higher level hierarchy cellview and I run the LVS, Diva doesn't recognize the Inductor component. I guess the cellview auLvs must be created for the inductor component, but I don't know how to generate this cellview. I checked in Cadence Documentation but I didn't find any reference. Can you help me? |
Title: Re: auLvs Creation Post by bernd on Nov 9th, 2005, 10:45am The 'auLvs' view is nothing more than a stopping view for the Diva netlister. Which means this view is needed for schematic netlist generation if you netlist with CDS_Netlisting_Mode=Analog. The default switch view list here is ("auLvs" "schematic" ). If you miss that view you should probably get a warning by Diva similar to these: Cannot find switch master cell for instance etc. ... Anyhow you can create a auLvs view if you simply copy your symbol view to the name auLvs, but you should be aware that the Diva netlister stops then at this cell and makes an netlist entry. BUT as on your description I assume that your problem is caused on the layout side and your inductor is not recognized by the device extraction. Have you checked your extracted view if there is an inductor included and your divaEXT.rul file if inductors are covered here! Bernd |
