https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> DC solver failed https://designers-guide.org/forum/YaBB.pl?num=1131080044 Message started by vijay on Nov 3rd, 2005, 8:54pm |
Title: DC solver failed Post by vijay on Nov 3rd, 2005, 8:54pm Hi friends, I am trying to simulate a maneatis symmetric load.While trying to simulate for its dc OP, spectre says A2=0 and Pcdibl2= negative. This is a cpnvergence error as i see it. setting the options for gmin convergence also does not help. Looking out for suggestions. Thanks in advance, |
Title: Re: DC solver failed Post by Andrew Beckett on Nov 4th, 2005, 5:13am a2 and pdiblc2 (I assume that's what you meant) are bsim3v3 and bsim4 model parameters. I'm assuming it's complaining about these parameters being out of range. Since you gave no useful information about what exactly the error was, it's ahrd to be sure. Perhaps you're simulating with device sizes which are too large? Can't really tell... it would have helped if you'd posted the exact error message. Regards, Andrew. |
Title: Re: DC solver failed Post by Geoffrey_Coram on Nov 14th, 2005, 8:21am I've seen warnings like those before; I think some foundries set values for these parameters that seemed "unlikely" to the people who implemented BSIM3 in Spectre. The warnings don't come from the original Berkeley code, as far as I know. But as Andrew said, they're model parameters, and the warnings really don't mean anything as far as convergence of the circuit. |
