https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> simulating DAC nonlinearity https://designers-guide.org/forum/YaBB.pl?num=1131462889 Message started by vivkr on Nov 8th, 2005, 7:14am |
Title: simulating DAC nonlinearity Post by vivkr on Nov 8th, 2005, 7:14am Hi, I am wondering how best to simulate the nonlinearity of my 12-bit DAC. Basically, I need to consider mismatch effects in order to see the INL/DNL, but if I do this with a Monte Carlo run, then it is practically impossible, since each single run itself takes several hours and generates a lot of data. Is there an efficient way of simulating the nonlinearity of a DAC? Would it be sufficient if I just simulate the nonlinearity around the major carry transition? Regards Vivek |
Title: Re: simulating DAC nonlinearity Post by Visjnoe on Nov 8th, 2005, 11:52am Hi, a lot depends of course on your DAC architecture, but in general my suggestions are: 1. For the static non-linearity (INL/DNL), if you don't want to take the simulation penalty imposed by Monte-Carlo, I would resort to behavioral/macro-modeling. If you only simulate the worste case transition, you have to make sure it's really worst case (can you ever be sure...I'd prefer a verification which checks all DAC input codes...) 2. For the dynamic non-lineariry: apply a sine wave near the Nyquist frequency at the DAC input. Hope this helps a bit Kind Regards Peter |
