https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Data export problem https://designers-guide.org/forum/YaBB.pl?num=1131496103 Message started by KiYoung on Nov 8th, 2005, 4:28pm |
Title: Data export problem Post by KiYoung on Nov 8th, 2005, 4:28pm I have problems with getting data in text file format from the AMS simulation results. Simvision does NOT have "print" option as in calculator. I searched all over the pull-down menus and also manuals, but couldn't find it. Also, it seems DirectPlot of AMS menu does not work for current. Even if I select a terminal, Simvision waveform viewer displays nothing, although voltages are displayed well. Am I supposed to set something up before simulation? Lots of thanks in advance, KiYoung |
Title: Re: Data export problem Post by KiYoung on Nov 8th, 2005, 5:20pm Sorry, folks. It was under File->Export.... in Simvison. But, current probing is still not functional. KiYoung |
