Design Languages >> Verilog-AMS >> AMS Beginer: Need help w/ AMS netlisting from HED
https://designers-guide.org/forum/YaBB.pl?num=1133693380
Message started by Saroj Rout on Dec 4th, 2005, 2:49am
Title: AMS Beginer: Need help w/ AMS netlisting from HED
Post by Saroj Rout on Dec 4th, 2005, 2:49am
I am just starting to do mixed-mode top level simulation in AMS using Cadence environment.
I am interested in the following methodology:
1) Creat config view using Hierarchy editor. For every block I will selecting either a AMS model, transistor level model or verilog-A model.
2) Once I have created the config view, I want to netlist this particular config view into a AMS (or any other appropriate ) netlist.
3) I want to instatiate the above netlist in my testbench which is written in AMS language (NOT a schematic).
4) Use ncverilog (or any other appropriate simulator) to simulate the above AMS testbench.
5) Once simulated I want to use AWD viewer in cadence to view the result.
Here are my questions:
1) Once I create the config view, how do I create a AMS netlist of the whole hierarchy ?
2) If I am compiling my testbench in command line, how do I include the connect modules ?
3) If I use ncverilog to compile the AMS testbench, is it possible to use AWD to view the result ?
I am in severe time crucnch, any help will be greatly appreciated.
Thanks
Saroj Rout
Analog Designer
Title: Re: AMS Beginer: Need help w/ AMS netlisting from
Post by jbdavid on Aug 3rd, 2006, 5:03am
This is probably a year late, but maybe it will help someone..
( I was in severe time crunch then also, so not reading the forum)
a config view is a "configuration" of some "design" view..
you already have to have specified the design you want to configure..
In cadence this will generally be a schematic, so you also need symbols for all the blocks, devices you are putting in your design..
Alternatitvely you can just create a verilogams netlist of the top level..
you can specify psf format for your analog outputs, then AWD can read them, but wavescan can read both analog and digital signals
