https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Environment options in ADE https://designers-guide.org/forum/YaBB.pl?num=1133889488 Message started by sutapanaki on Dec 6th, 2005, 9:18am |
Title: Environment options in ADE Post by sutapanaki on Dec 6th, 2005, 9:18am Hi, I'd like to do the following: everytime I start Analog Design Environment in Cadence icfb I would like to include a file. And this would be a different file for different technologies. Also, for a given technology I'd like to have the same file loaded no matter if I start a new schematic/simulation or I'm resimulating an old one. I guess I can do this by filling the field include file in Setup>Environment... in ADE. My question is how to make it load by default? What is the file that keeps the environment options (other than .cdsenv in my project dir) and where is it stored? TIA Svilen |
Title: Re: Environment options in ADE Post by Andrew Beckett on Dec 6th, 2005, 2:55pm You could probably use: Code:
in your .cdsinit file, or the equivalent .cdsenv entry. Andrew. |
