https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> PCI-Express jitter frequency definition https://designers-guide.org/forum/YaBB.pl?num=1134796497 Message started by neoflash on Dec 16th, 2005, 9:14pm |
Title: PCI-Express jitter frequency definition Post by neoflash on Dec 16th, 2005, 9:14pm Hi, It looks there is no definition of the jitter frequency for PCI-Ex. Then it is hard to know that phase noise should be integrated over what frequence range. thanks, Neoflash |
Title: Re: PCI-Express jitter frequency definition Post by cktman on Jan 13th, 2006, 5:27pm Are you referring to the clock spec? If so there is a jitter white-paper on the pcisig site. http://www.pcisig.com/specifications/pciexpress/technical_library/PCI_Express_Jitter_White_Paper_1_0_May_27_20043.pdf The actual spec is the PCIe CEM Spec but your company has to be a member to access it. |
