https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> epitaxial layer https://designers-guide.org/forum/YaBB.pl?num=1134990963 Message started by river on Dec 19th, 2005, 3:16am |
Title: epitaxial layer Post by river on Dec 19th, 2005, 3:16am anybody who knows the purpose of epitaxial layer? Why not make transisters in p-sub directly? |
Title: Re: epitaxial layer Post by kwkam on Dec 19th, 2005, 5:40am Epi layer is often used in the bipolar process. Usually, it make a N or P buried layer on the surface of P-sub. Then a layer of monolithic Si grow on the top of Buried layer for further step. For more detail, you can read some semiconductor process book. |
Title: Re: epitaxial layer Post by Paul on Dec 19th, 2005, 1:20pm Epi substrates usually have lower resistivity compared to plain processes. For some reason, it is frequently used in bipolar and BiCMOS processes, I believe. Due to the lower resistivity, it minimizes the risk of latch-up. It seems to me it used to be very popular during a couple of process generations for digital circuit design (maybe somebody else can confirm this?). It is however terrible in terms of substrate noise, because the noise almost propagates everywhere. Paul |
Title: Re: epitaxial layer Post by river on Dec 20th, 2005, 3:28am why process guys don't integrate transistors in the heavily doped p-sub layer? what's the limitation? |
Title: Re: epitaxial layer Post by Geoffrey_Coram on Dec 22nd, 2005, 9:17am Wouldn't the collectors of all the PNPs be shorted together, if the PNPs were made in the p-sub layer? |
Title: Re: epitaxial layer Post by river on Dec 22nd, 2005, 4:44pm here I am talking about cmos process, not bipolar. anybody knows the reason? |
Title: Re: epitaxial layer Post by sheldon on Dec 22nd, 2005, 5:50pm River, Epitaxial layers are used because they are more lightly doped than the layers below them. Growing an epitiaxial layer is the only method to create a more lightly doped layer on top of a more highly doped layer. For bipolars, an n-epitaxial is used. This layer allows npn transistors to have an N+ buried subcollector. The buried subcollector suppresses the beta of the vertical pnp inherent in the npn structure. For CMOS transistors, a p+ wafer is used with a p-epitaxial layer to suprress the beta of the parasitic bipolar that causes latch-up. Lower doped regions are preferred because the breakdown voltage is higher, the junction capacitances are lower, device output resistances are higher, device threshold voltages are higher, ... This is a fundamental challenge for our industry. Think about what happens as processes are scaled down from 0.35um --> 90nm. The doping concentration of the substrate increases meaning that the transistors have lower breakdown voltage, less output resistance, ... The p+ substrates are doped near to degeneracy, that is, they are more like "conductors" then "semiconductors". You can not build devices in transistors in a p+ substrate. Lateral pnp devices are built in n-epitaxial bipolar processes so the devices are isolated. In CMOS processes it is more typical to build vertical pnp transistors using n-well as a base. These device do not have an isolated collectors. Best Regards, Sheldon |
Title: Re: epitaxial layer Post by river on Dec 26th, 2005, 7:34am Sheldon thank you very much. :P River |
