https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Question about Cadence modeling inductor https://designers-guide.org/forum/YaBB.pl?num=1136468997 Message started by yiping on Jan 5th, 2006, 5:49am |
Title: Question about Cadence modeling inductor Post by yiping on Jan 5th, 2006, 5:49am Cadence can modeling spiral ind , transformer based on the tech file! My quesition is: Whether cadence will modeling more complex inductor( eg. symind) instead of simple spiral ind? Thanks!! |
Title: Re: Question about Cadence modeling inductor Post by bernd on Jan 5th, 2006, 6:28am There is a new tool 'Passive Component Modeler' comes with the MMSIM 6.0 URS2 stream. Have a look at Code:
I it can model a set of more complex inductors like differential symmetrical and asymmetrical, based on a Assura procfile and p2lvs file. I have not tested it so far. Try with: Code:
Bernd |
Title: Re: Question about Cadence modeling inductor Post by Andrew Beckett on Jan 7th, 2006, 8:20am It's also integrated with DFII - there's a tutorial under the vpcm directory in the installation. Regards, Andrew. |
Title: Re: Question about Cadence modeling inductor Post by yiping on Jan 10th, 2006, 1:02am Thanks lot!!! Bernd and Andrew, Let me try the tools firstly and get back to you later. Great Information!!! Yiping |
