https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> syntax error `include https://designers-guide.org/forum/YaBB.pl?num=1136655267 Message started by billtsang on Jan 7th, 2006, 9:34am |
Title: syntax error `include Post by billtsang on Jan 7th, 2006, 9:34am Hi, I got syntax error when i " `include "constants.h" ". Can anyone point out the reason. Error found by spectre during AHDL read-in. "th.def", line 10: "`<<--? include "constants.h"" "th.def", line 10: Error: syntax error "th.def", line 14: "electrical <<--? Pin, Nin, Pout, Nout ;" "th.def", line 14: Error: invalid module terminal type (*undef*) for Pout. "th.def", line 14: Error: invalid module terminal type (*undef*) for Nout. "th.def", line 14: Error: invalid module terminal type (*undef*) for Pin. "th.def", line 14: Error: invalid module terminal type (*undef*) for Nin. "th.def", line 14: Error: syntax error Maximum allowable errors exceeded. Exiting SpectreHDL compilation.... // Periodic Track & Hold // // Works with SpectreRF (has no hidden state) // Almost ideal ... // Has buffered input and output (infinite input Z, zero out Z) // Exhibits no offset or distortion errors // Only nonideality is finite aperture time and very small amount of droop `include "constants.h" `include "disciplines.h" module th (Pout, Nout, Pin, Nin) (period, delay, aperture, tc) electrical Pin, Nin, Pout, Nout ; input Pin, Nin; output Pout, Nout; parameter real period=16n from (0:inf); parameter real delay=0 from (0:inf); parameter real aperture=period/2 from (0:period/2); parameter real tc=aperture/10 from (0:aperture); integer n; real tstart, tstop; electrical hold; analog begin // Determine the point where the aperture begins; n = ($abstime - delay + aperture) / period + 0.5; tstart = n*period + delay - aperture; @(timer(tstart)); // Determine the time where the aperture ends; n = ($abstime - delay) / period + 0.0; tstop = n*period + delay; @(timer(tstop)); // Implement switch with effective series resistence of 1 Ohm if (($abstime > tstop - aperture) && ($abstime <= tstop)) I(hold) <+ V(hold) - V(Pin, Nin); else I(hold) <+ 1.0e-12 * V(hold); // Implement capacitor with an effective capacitance of tc I(hold) <+ tc * ddt(V(hold)); // Buffer output V(Pout, Nout) <+ V(hold); // Control time step tightly during aperture and loosely otherwise if (($abstime >= tstop - aperture) && ($abstime < tstop)) begin $bound_step(tc); end else begin $bound_step(period/5); end end endmodule |
Title: Re: syntax error `include Post by Andrew Beckett on Jan 9th, 2006, 11:38am A few points: 1. Don't give the filename the suffix ".def". This tells the ahdl_include in spectre that the file is spectreHDL, not Verilog-A. Your code is (mostly) VerilogA - the bits which aren't is probably a mistake... 2. You list the parameter names on the module line. That's spectreHDL syntax, and shouldn't be there for Verilog-A. So the module line should just be: Code:
3. Put the electrical definition after the port directions. It will work in spectre (with a warning these days), but in other tools they may be more strict and require the port direction before the discipline. For example: Code:
4. delay is a reserved word. I had to change the parameter to something else (I used "del"). |
Title: Re: syntax error `include Post by Andrew Beckett on Jan 9th, 2006, 11:39am I meant to say that after all that, it compiles in both spectre and AMS Designer. I didn't check that the code works 8-) Andrew. |
Title: Re: syntax error `include Post by jbdavid on Jan 10th, 2006, 4:41am In verilog - the parameters (if included in the module declaration header ) go BEFORE the pin declarations.. I've never used this feaure of Verilog2001 .. jbd |
