https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Simulationg a trim procedure using ocean https://designers-guide.org/forum/YaBB.pl?num=1138202784 Message started by achim.graupner on Jan 25th, 2006, 7:35am |
Title: Simulationg a trim procedure using ocean Post by achim.graupner on Jan 25th, 2006, 7:35am Dear all, I spent part of the day to write an ocean script for verifying the impact of trimming. It does the following: 1. it does a simulation at nominal operating conditions for a random realization of the circuit's device parameters 2. it computes a trimmung value 3. it repeats the above simulation for the *same* random realization of the circuit's device parameters to check whether the trimming was sucessful 4. it repeats the simulation for different operating condition, again for the *same* random realization of the circuit's device parameters The code could surely be optimized ... The example is an amplifier (which later will be part of a trimmed signal path) Regards, achim |
