https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Ideal switch with piece wise linear resistance. https://designers-guide.org/forum/YaBB.pl?num=1139368820 Message started by venky on Feb 7th, 2006, 7:29pm |
Title: Ideal switch with piece wise linear resistance. Post by venky on Feb 7th, 2006, 7:29pm Does anyone know how to build a piecewise linear switch ( A switch whose resistance varies with input voltage). Background of the problem : In switch cap circuits typically the initial design is done with ideal switches. These ideal switches go from ON resistance of a few ohms to OFF resistance of teraohmes(which u can set) . Such abrupt changes in resistance causes convergence issues in spectre. If we can build a switch which changes its resistance in linear way then simulators should not have that problem. |
