https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Spectre model section handled like a variable ? https://designers-guide.org/forum/YaBB.pl?num=1141230092 Message started by ACWWong on Mar 1st, 2006, 8:21am |
Title: Spectre model section handled like a variable ? Post by ACWWong on Mar 1st, 2006, 8:21am Can a spectre model section be handled like a variable is Cadence ? I am using IC5.1.41 and using the corners tool, is there an easy way to do multiple corners with the same section or handle the model section like a variable (this would be nice for parametric simulation as well). I know i can do what i want in OCEAN, but just wondered if there is an easy way to do this using the corners or artist GUIs ? |
