https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> PWM switch model https://designers-guide.org/forum/YaBB.pl?num=1141310427 Message started by MokoKoya on Mar 2nd, 2006, 6:40am |
Title: PWM switch model Post by MokoKoya on Mar 2nd, 2006, 6:40am hello everybody, I need to run an ac simulation on boost converter working in CCM mode to find out the best error amplifier compensation. I therefore need to create the small signal model of the PWM switch in verilog-a. I have created a model based on a spice model from a paper "A tutorial introduction to simulating current mode power stages." The results that I get are not as acurate as the mathamatical simulations that I have previously ran in OCTAVE. (resonance frequency shift, DC op-point output voltage differs slightly with different duty cycles, and magnitude). Attached is the verilog-a source code and the mathematical transfer function from OCTAVE (Gvd). Does any body have any suggestions????? Also any links to other models that I can base the design on? |
Title: Re: PWM switch model Post by Jess Chen on Mar 2nd, 2006, 8:11am I don't see the VerilogA code. Did you forget to post it or am I not seeing a download button? -Jess |
Title: Re: PWM switch model Post by MokoKoya on Mar 3rd, 2006, 1:32am hello, Good point, I can't find the download button either! here is my verilogA code and OCTAVE calculation. // VerilogA for power, PWM_switch_3, veriloga `include "constants.vams" `include "disciplines.vams" module PWM_switch_3(c, a, p, cont, vin); inout c, a, p, cont, vin; electrical c, a, p, cont, n1, n2, n3, vin; parameter real R0 = 27; //output load parameter real VD = 800m; //diode voltage parameter real RL = 190m; //coil resistance parameter real Rdson = 500m; //transistor resistance parameter real IA = 700m; //output current parameter real Rcap = 500m; //ESR capacitor parameter real Rdiode = 10m; //diode resistance parameter real Rm = 0.0; //modulation resistance real IC, VAP; //internal DC parameters real VPA, IP, QB, QA, QC, D, Re, Rc; branch (n1, a) vcvs_1; branch (a, p) vccs_1; branch (n1, p) cccs_1; branch (n2, p) vcvs_2; branch (c, n2) Rs; analog begin @(initial_step) begin //DC operation point calculation VPA=IA*R0*2+6; IP=IA/(2*1.517) + 0.05; QA=Rdson*IP; QB=(VPA+IP*(RL-Rdson)); QC=(V(vin) -VPA-IP*RL-VD); VAP=-VPA; D=(-QB + (sqrt(QB*QB -4*QA*QC)))/ (2*QA); IC = IP / (1 - D); Re = (Rcap * VPA)/(Rcap*IP + VPA); Rc = Rm +/* (D*Rdson) + ((1-D)*Rdiode) + */(Re*D*(1-D)); if(analysis("dc"))begin V(vcvs_1) <+ 0.0; //n1, a I(vccs_1) <+ 0.0; //a, p I(cccs_1) <+ -IC * D; //n1, p V(vcvs_2) <+ VAP * D ; //n2, p V(Rs) <+ IC * Rc; //n3, c end end//initial_step if (analysis("ac"))begin V(vcvs_1) <+ V(cont) * (VAP / D); //n1, a I(vccs_1) <+ V(cont) * -IC; //a, p I(cccs_1) <+ -I(Rs) * D; //n1, p V(vcvs_2) <+ V(cccs_1) * D ; //n2, p V(Rs) <+ I(Rs) * Rc; //n3, c end end endmodule and the octave calculations G0=Vin/(1-D)^2; G0dB=20*log10(G0) wz1=1/(RC*C); fz1=wz1/(2*pi); wz2=(R0*(1-D)^2 -RL)/L; fz2=wz2/(2*pi); w0=(1/(L*C)^(0.5))*( RL/R0 + (1-D)^2)^(0.5); f0=w0/(2*pi) Q=w0/(RL/L + 1/(C*(R0+RC))); Gvd=G0*(1+s/wz1).*(1-s/wz2)./(1+(s/(w0*Q))+((s.^2)/(w0^2))); The circuit I place the model into is a boost converter (open loop), with V(cont) input being an AC source representing the small signal varience of the duty cycle. Thank you, Andrew |
Title: Re: PWM switch model Post by Geoffrey_Coram on Mar 3rd, 2006, 4:26am MokoKoya - I think you're rather confused about how to make a Verilog-A model work for ac analysis. The simulator is responsible for linearizing the model at the operating point. I don't think you want if(analysis()) in your code. If I write a diode as I(a,c) <+ Isat * (exp(V(a,c)/$vt) -1 ); (without using analysis()), then this equation will be evaluated at dc (and in transient), and the simulator will automatically compute that the ac current is Isat/$vt * exp(Vdc(a,c)/$vt) * Vac(a,c), where Vdc is the voltage found in the dc analysis and Vac is the ac magnitude. |
