https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Multiple modules in verilog https://designers-guide.org/forum/YaBB.pl?num=1142982773 Message started by ness9660 on Mar 21st, 2006, 3:12pm |
Title: Multiple modules in verilog Post by ness9660 on Mar 21st, 2006, 3:12pm Ive always just been a c/c++ and java programmer. So the idea of using functions is only natural to me, but the following code does not want to work in xilinx. Lets say Im going to make a 8x1 mux using two 4x1 muxes and a 2x1. Can I just use modules in the same manner as c/c++? For example Code:
In that example all three modules are contained within mux8x1.v, but this will does not seem to work. I cant find any resources online. Whats the proper way to use multiple modules? |
Title: Re: Multiple modules in verilog Post by Geoffrey_Coram on Mar 22nd, 2006, 9:06am You want to instantiate the sub-elements in the main module, not call them like functions. Something like mux_4x1 mymuxa(i0, i1, i2, i3, c1, c0, temp1); mux_4x1 mymuxb(i4, i5, i6, i7, c1, c0, temp2); mux_2x1 mymuxc (temp1, temp2, c2, result); Same sort of thing has to be done in mux_2x1 for the "and" and "or", I think. (Where are they defined?) |
