https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> rapid poweron opamps https://designers-guide.org/forum/YaBB.pl?num=1143021462 Message started by vivkr on Mar 22nd, 2006, 1:57am |
Title: rapid poweron opamps Post by vivkr on Mar 22nd, 2006, 1:57am Hi, I am wondering if there is a good way to turn on a high-gain opamp (DC gain ~ 90 dB) from a standby condition to fully accurate operation mode (fully loaded) in a short duration (~100ns). Any ideas will be appreciated? I am interested in using the opamp in a circuit which works in burst-mode, and is usually turned off or placed in standby to save power. Regards Vivek |
Title: Re: rapid poweron opamps Post by Paul on Mar 23rd, 2006, 12:44pm Hi Vivek, 100ns seems quite short for complete wake-up, but you may find some interesting ideas in the domain of switched op-amp circuits introduced by Crols and Steyaert (that's at least my earliest reference). In this technique, some switches in switched-capacitor circuits are moved inside the amplifier, which output is switched to high impedance in one clock period. It may be worth having a look at the following paper: Switched-opamp: an approach to realize full CMOS switched-capacitor circuits at very low power supply voltages Crols, J.; Steyaert, M.; IEEE Journal of Solid-State Circuits Volume 29, Issue 8, Aug. 1994 Page(s):936 - 942 Paul |
