https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> offset cancellation of comparators/opamps https://designers-guide.org/forum/YaBB.pl?num=1144336178 Message started by vivkr on Apr 6th, 2006, 8:09am |
Title: offset cancellation of comparators/opamps Post by vivkr on Apr 6th, 2006, 8:09am Hi, I know of a couple of different schemes for offset cancellation of comparators/opamps, but would be interested in knowing if there is any paper or book where a review of various methods for offset cancellation is presented. Thanks Vivek |
Title: Re: offset cancellation of comparators/opamps Post by JJ on Apr 6th, 2006, 3:21pm You might want to check out the book "Principles of Data Conversion System" by Razavi. Hope it helps. |
Title: Re: offset cancellation of comparators/opamps Post by Paul on Apr 7th, 2006, 1:10am Vivek, may I refer you to a previous post with various reading material suggestions: http://www.designers-guide.org/Forum/YaBB.pl?num=1141147092/3#3 Do these cover your issues? Paul |
Title: Re: offset cancellation of comparators/opamps Post by vivkr on Apr 11th, 2006, 12:17am Dear Paul, JJ, Many thanks for your replies. They are all very useful. Regards Vivek |
Title: Re: offset cancellation of comparators/opamps Post by Pavel on Apr 15th, 2006, 10:42am Hello Vivek There is good article that treats this topic "Circuit Techniques for Reducing the Effects of Op-Amp Imperfections: Autozeroing, Correlated Double Sampling, and Chopper Stabilization" by Christian Enz & Gabor Temes. Hope it will help. Good luck. Pavel. |
